killshee Posted January 28, 2009 Report Posted January 28, 2009 i just bought 8 inch wheels for my banshee bc all of the local racers around here run 8inch and i can get cheep tires.... should i re-gear it? and what would be a good gear change? Quote
killshee Posted January 28, 2009 Author Report Posted January 28, 2009 anyone running smaller wheels/tires on the back? Quote
twizted269 Posted January 28, 2009 Report Posted January 28, 2009 if you run the same size tire just on an 8 rim, whats the point of regearing? Quote
killshee Posted January 28, 2009 Author Report Posted January 28, 2009 if you run the same size tire just on an 8 rim, whats the point of regearing? the tires r smaller in diameter Quote
notsed Posted January 28, 2009 Report Posted January 28, 2009 what size tires did you have and what size are you putin on? rim size doesnt make a diff i gearing Quote
05.Banshee.SE Posted January 28, 2009 Report Posted January 28, 2009 No one knows your riding style, or what terrain you're riding...put the things on, and take it out riding. Then decide for yourself what you need. Quote
dragbanshee Posted January 28, 2009 Report Posted January 28, 2009 Like 05 said! It does change your gearing depending on the size, try it and see, you may like it. Quote
