kbone77 Posted January 21, 2009 Report Posted January 21, 2009 back to the 4mm port question-you'll also need to consider whether or not you're going to use a spacer plate under the jugs or the other option is to use a head/dome too allow the longer stroke. that will effect how it is ported too. I'd recommend the head, don't mess w/ the spacer (less gaskets). Also the previous post was correct, the 795 pistons only acct for the longer rod. just my 2cents from my 4mm crank experience.. Quote
