uwenr Posted January 20, 2009 Report Posted January 20, 2009 yesyes yes youll feel the diffrence between the 4 and the 7(with the right porting) I second that, thats what i run Quote
SonOfSand Posted January 20, 2009 Report Posted January 20, 2009 Yes, a 7mm will work but must be done carefully and correctly. We will not do a 10mm crank on stock cylinders any more because they just suck compared to the cub motors from lack of transfer volume/flow. ie, you can't feed it very well. They also suffer big time from port timing being way out of the bubble for optimal performance. In our opinion, the 7mm is the largest sensible crank for the stock cylinders. Brandon Hi, new to this forum, are you a builder? I am making a list of builders to choose from. thanks Quote
