camatv Posted January 10, 2009 Report Posted January 10, 2009 i am selling my trail/ dune riding banshee this is an all new motor i JUST got this done its been to our local riding spot and has about 2 tanks of fuel through it. engine is a stocker'd cylinder'd 350cc motor has agressive dune trail porting makes a LOT of midrange and tq and revv's VERY hard on top. its a LOT of fun to ride and is set up well for trails and dunes the power is more emphasized in the middle of the rpm's its a lot easier to ride than a drag port or stock.. dyno'd at 65 hp and a very broad tq range in the 45's engine: 350cc 64.5mm stock pistons, stock crank trued and welded all brand new pro design head with 19cc domes agressive trail porting with emphasis in the transfer area for broad power 193* exhaust and 130* transfer timing v-force reeds with modd'd stock intakes, 30mm pwm d slide kehien carbs ( NICE carb) k+n filters w velocity stacks hinson clutch basket ebc clutch stiffer springs stock transmission with new shift pins all billet covers and inserts +4 timing and lightened flywheel 200watt single line stator ALL new wiring harness off of an 1998 TORRS removed t-5 chrome pipes repacked silencers FRAME: +4 lonestar round housing carrier swing arm full gusset for jumping, 250r rear axle ( chrome) uses honda bolt pattern wheels, and 250r rear brake caliper, brake disk has billet antifade lock nut on it also rpm gold billet bearing carrier, PEP revalved. resprung shock works front triple rate shocks, braided front brake lines uses the 87 style BIG front brake calipers renthal fat bars with billet adapters gytr yamaha front bumper ( rare!!!) CHROME footpegs kickstarter and brake pedal billet covers and accesories on the bike everywhere powdercoated silver veign frame nerf bars with solid mounts to the frame ( no shaking or falling off) front and rear full bore plastics custom painted/ air brushed in good shape nac's racing seat bike is very quick and reliable its easy to ride you can put it around it wont foul plugs i can trail ride it for a while and hit the gas it comes right on its jetted nearly perfect.. i cannot emphasize how much fun this is to ride and how nice of a ride it really is. it needs all the alluminum repolished and it would look great also.. of course its faster than most any yfz. i have a set of sand tires that will sell with it and an extra set of rear wheels for another tire combo if wanted. have a set of +3 alba arms i will include asking 4800 out of it. this is a real modded banshee with thousands in aftermarket parts i hate to sell it but i need the $$$ to buy a house. i will take the plastics off for black stockers and remove a lot of the billet for a lower price.? please call 620 259 6178 620 802 8807 Quote
jerseyrider Posted January 19, 2009 Report Posted January 19, 2009 Is this a part out ^^^^^^^^^^^^^^??????? Quote
