kodie Posted January 3, 2009 Report Posted January 3, 2009 Bought the chariot timing plate what should I set it at? Currently putting in a 4 mil. woods port It's getting bored 60 over pro circuits cool head with custom I think 22's maybe 21 domes. 2 into 1 trinity 35 carb with k & n no box. 886 above sea level. Not sure what info you needed but thats all I could think of that would help. :shrug: Also only 1 person has told me the 35 won't be able to handle the 4 mil by its self. Do I buy another 35? or go with 2 other smaller ones? The bike should be put back together in about 2-3 weeks. Quote
RUDEDAWG Posted January 3, 2009 Report Posted January 3, 2009 Who ever did the port job should tell you the optimum timing you should run and also the carb set up providing you just got it ported by a professional shop. Otherwise +4 timing is a safe margin for your set up and one 35mm carb will work well with a woods port which is a good low range port job, as long as you don't go drag racing. Quote
AKheathen Posted January 3, 2009 Report Posted January 3, 2009 Bought the chariot timing plate what should I set it at? Currently putting in a 4 mil. woods port It's getting bored 60 over pro circuits cool head with custom I think 22's maybe 21 domes. 2 into 1 trinity 35 carb with k & n no box. 886 above sea level. Not sure what info you needed but thats all I could think of that would help. :shrug: Also only 1 person has told me the 35 won't be able to handle the 4 mil by its self. Do I buy another 35? or go with 2 other smaller ones? The bike should be put back together in about 2-3 weeks. everything but the woods port on that setup leads to a real peaky power band, but snoopczinski recently did a real detailed analisys on the subject. i belive it was 2 28mm mikunis'. i'll bump it for ya. Quote
AKheathen Posted January 3, 2009 Report Posted January 3, 2009 general banshee discussion :thumbsup: Quote
kodie Posted January 3, 2009 Author Report Posted January 3, 2009 general banshee discussion :thumbsup: Ya I saw it thanks. His motor is stock stroke will the 4 mil make it want more gas? Won't I need a lil more than 28's? Quote
firebanshee Posted January 3, 2009 Report Posted January 3, 2009 Ya I saw it thanks. His motor is stock stroke will the 4 mil make it want more gas? Won't I need a lil more than 28's? Your pro circuit pipes are going to need huge carbs, and for trail and woods riding you don't want big carbs, you could go a little bigger on the carbs but i would not go a whole lot more unless you plan on future mods that would require bigger cabs.+4 on the timing would be really safe with 93 octane fuel. Quote
