Bought the chariot timing plate what should I set it at?
Currently putting in a 4 mil.
woods port
It's getting bored 60 over
pro circuits
cool head with custom I think 22's maybe 21 domes.
2 into 1 trinity 35 carb with k & n no box.
886 above sea level.
Not sure what info you needed but thats all I could think of that would help. :shrug:
Also only 1 person has told me the 35 won't be able to handle the 4 mil by its self. Do I buy another 35? or go with 2 other smaller ones?
The bike should be put back together in about 2-3 weeks.
Who ever did the port job should tell you the optimum timing you should run and also the carb set up providing you just got it ported by a professional shop. Otherwise +4 timing is a safe margin for your set up and one 35mm carb will work well with a woods port which is a good low range port job, as long as you don't go drag racing.
woods port
pro circuits
everything but the woods port on that setup leads to a real peaky power band, but snoopczinski recently did a real detailed analisys on the subject. i belive it was 2 28mm mikunis'. i'll bump it for ya.
general banshee discussion :thumbsup:
Ya I saw it thanks. His motor is stock stroke will the 4 mil make it want more gas? Won't I need a lil more than 28's?
Your pro circuit pipes are going to need huge carbs, and for trail and woods riding you don't want big carbs, you could go a little bigger on the carbs but i would not go a whole lot more unless you plan on future mods that would require bigger cabs.+4 on the timing would be really safe with 93 octane fuel.
