lunatic Posted December 30, 2008 Report Posted December 30, 2008 I need some #2 forks in good shape. I got a set off ebay that were half galled. thanks Quote
FASTOYS Posted December 30, 2008 Report Posted December 30, 2008 I have a used #1 but that prolly wont help ya. Why not buy new as it is only a $28 part??? I keep em if i can help and we are only a day away from you! Quote
lunatic Posted December 30, 2008 Author Report Posted December 30, 2008 I have a used #1 but that prolly wont help ya. Why not buy new as it is only a $28 part??? I keep em if i can help and we are only a day away from you! My tranny dosent even use #1 forks so thats why i need #2s. It eats forks left and right so putting in new is just a waste tell i figure out why? Bill robinson said its probably undertired or is bouncing off the limiter or the clutch is slipping to burn forks like it does? Quote
NYUK Posted December 30, 2008 Report Posted December 30, 2008 check my e bay stuff. i got an rz tranny. i used to burn and sharpen forks till i put rz forks in. Quote
lunatic Posted December 30, 2008 Author Report Posted December 30, 2008 The only difference is in the pin thats spins that goes in the drum right? I guess i dont see how a rz fork could last longer when all the wear is where it contacts the clutch sides? Quote
FASTOYS Posted December 30, 2008 Report Posted December 30, 2008 My tranny dosent even use #1 forks so thats why i need #2s. It eats forks left and right so putting in new is just a waste tell i figure out why? Bill robinson said its probably undertired or is bouncing off the limiter or the clutch is slipping to burn forks like it does? I see, Definetly need to find out what is going on then huh?!! I was also gonna say Im sure NYUK prolly has a bucket of used ones , check with him. Quote
NYUK Posted December 30, 2008 Report Posted December 30, 2008 The only difference is in the pin thats spins that goes in the drum right? I guess i dont see how a rz fork could last longer when all the wear is where it contacts the clutch sides? they are a lil beefier if you hold a yfz and an rz side by side. rz forks in my override did not get sharpened after 1 year. Quote
