jasons Posted December 26, 2008 Report Posted December 26, 2008 ok i pulled my flywheel off to change out the stator and just for giggles i shook it and there is something inside like its broken shakeing around. is my flywheel bad. could this be another reason why i am getting no spark. t hanks Quote
firebanshee Posted December 27, 2008 Report Posted December 27, 2008 ok i pulled my flywheel off to change out the stator and just for giggles i shook it and there is something inside like its broken shakeing around. is my flywheel bad. could this be another reason why i am getting no spark. t hanks YES, your magnets are broken and without your magnets no sparky sparky. Quote
jasons Posted December 27, 2008 Author Report Posted December 27, 2008 YES, your magnets are broken and without your magnets no sparky sparky. dang and i just spent 160 bicks on a new stator. and 100 bucks on a coil 30 dollars for a cdi. guess i am off to ebay to find a flywheel. thanks. jason Quote
firebanshee Posted December 27, 2008 Report Posted December 27, 2008 dang and i just spent 160 bicks on a new stator. and 100 bucks on a coil 30 dollars for a cdi. guess i am off to ebay to find a flywheel. thanks. jason Yep. :cool: You should advance your timing +4 while you have your flywheel off it makes a HUGE difference and it is free if you slot your own stator or you can buy one for 35$ Quote
jasons Posted December 27, 2008 Author Report Posted December 27, 2008 Yep. :cool: You should advance your timing +4 while you have your flywheel off it makes a HUGE difference and it is free if you slot your own stator or you can buy one for 35$ it has a aftermarket plate on it that can be advanced all the way to +10 it was on +2 when i took it off. looking for a flywheel know. thanks for the help Quote
firebanshee Posted December 27, 2008 Report Posted December 27, 2008 it has a aftermarket plate on it that can be advanced all the way to +10 it was on +2 when i took it off. looking for a flywheel know. thanks for the help Yep :cool: Quote
