klemet banshee Posted December 14, 2008 Report Posted December 14, 2008 so i know that if u run a 2into 1 intake i will lose some top end but would that cause 6th gear to bogg? i goes into it and i takes maddd long to hit powerband. i also dont have the right jets in would that cause it? Quote
05.Banshee.SE Posted December 14, 2008 Report Posted December 14, 2008 Running to rich could do it. Quote
dirtfreak Posted December 14, 2008 Report Posted December 14, 2008 . is it just bogging,not cutting out or running erratic.you may need to rejet. what jets do you have now.what gears you have at the moment.how long has it been bogging. it runs solid 1rdt thru 5th. Quote
klemet banshee Posted December 14, 2008 Author Report Posted December 14, 2008 currently im running 175 mains with 58 pilots i also have the airbox lid on Quote
trex banshee Posted December 15, 2008 Report Posted December 15, 2008 currently im running 175 mains with 58 pilots i also have the airbox lid on what do your plugs look like? I know you told me that you run through a bunch of mud, but that airbox lid is killing its breathing! Quote
klemet banshee Posted December 15, 2008 Author Report Posted December 15, 2008 the right plug is a little black and the left is jus a tab bit white not white white but you could see a little bit on there Quote
trex banshee Posted December 15, 2008 Report Posted December 15, 2008 the right plug is a little black and the left is jus a tab bit white not white white but you could see a little bit on there sounds like you may have an air leak on the left side then. I would find it before you cause major damage. This will cause it to not run right and stump you on your jetting. you did replace all the gaskets when you put it back together didn't you? Quote
klemet banshee Posted December 15, 2008 Author Report Posted December 15, 2008 yea i replacd all the gaskets and i did a leakdown test and nothing Quote
