so i know that if u run a 2into 1 intake i will lose some top end but would that cause 6th gear to bogg? i goes into it and i takes maddd long to hit powerband. i also dont have the right jets in would that cause it?
is it just bogging,not cutting out or running erratic.you may need to rejet.
what jets do you have now.what gears you have at the moment.how long has it been bogging.
it runs solid 1rdt thru 5th.
currently im running 175 mains with 58 pilots i also have the airbox lid on
what do your plugs look like? I know you told me that you run through a bunch of mud, but that airbox lid is killing its breathing!
the right plug is a little black and the left is jus a tab bit white not white white but you could see a little bit on there
sounds like you may have an air leak on the left side then. I would find it before you cause major damage. This will cause it to not run right and stump you on your jetting. you did replace all the gaskets when you put it back together didn't you?
