oldskoolracer Posted December 3, 2008 Report Share Posted December 3, 2008 OK, we've tried alot of things, we replaced the CDI the COIL and the STATOR. all from ricky stator , still nothing. no spark whatso ever. what else is there we tried the tether kill connected and disconnected. and the main switch i don't get it i'm going nuts............ Quote Link to comment Share on other sites More sharing options...
1996dragshee Posted December 3, 2008 Report Share Posted December 3, 2008 check your grounds check the harness for a pinched or broken wire if you still have the tors on there get rid of that shit,thats probably where your problem is. Quote Link to comment Share on other sites More sharing options...
oldskoolracer Posted December 3, 2008 Author Report Share Posted December 3, 2008 all of the tors was removed before we got it. it just died one day, nothing wrong i don't get it. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted December 3, 2008 Report Share Posted December 3, 2008 Flywheel. And Ricky Stator stuff is garbage...see if you can return it for a refund and get used OEM equipment. Get a clymers, trace down the wiring. get rid of everything you don't need. Did you set the pickup gap properly between the flywheel nubs and the pickup coil? Quote Link to comment Share on other sites More sharing options...
oldskoolracer Posted December 3, 2008 Author Report Share Posted December 3, 2008 WOUDL THE VOLTAGE REG BE ANYTHING TO DO WITH IT? HOW WOULD THE FLYWHEEL BE DAMAGED? INSTALL OR WILL THE MAGNETS JUST GO BAD? Quote Link to comment Share on other sites More sharing options...
dajogejr Posted December 3, 2008 Report Share Posted December 3, 2008 You can unplug the voltage regulator. The only thing that is used for is to soak up volts so you don't smoke the light bulbs by over juicing them. Flywheels go bad. Magnets go bad...and they can break apart inside the flywheel. It'll sound like a maraca when you shake it. What did you adjust the pickup gap to on the flywheel? Quote Link to comment Share on other sites More sharing options...
XxMeltIcexX Posted December 3, 2008 Report Share Posted December 3, 2008 WOUDL THE VOLTAGE REG BE ANYTHING TO DO WITH IT? HOW WOULD THE FLYWHEEL BE DAMAGED? INSTALL OR WILL THE MAGNETS JUST GO BAD? No, the voltage regulator is strictly for the lights/tail light. I would definately check your ground first, you need to get an ohmmeter and start testing stuff! Quote Link to comment Share on other sites More sharing options...
oldskoolracer Posted December 3, 2008 Author Report Share Posted December 3, 2008 NO, WE DIDN'T CHANGE THE GAP IN THE FLYWHEEL BUT WE THOUGHT ABOUT CHECKING IT TO SEE IF IT WAS OFF WHAT SHOULD THE AIR GAP BE? IT SHOWS .015-.020 IS THIS CORRECT? I'M GOING TO GO HOME TONIGHT AND START CHECKING ALL THE GROUNDS. WE WENT THREW ALOT OF THE HARNESS AND HAVE YET TO FIND ANYTHING. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted December 3, 2008 Report Share Posted December 3, 2008 .015 to .020 is perfect. Please turn off the caps lock...it's like you're shouting. Run an extra ground from the coil mount the the engine ....just for giggles. Just because you have brand new Ricky Stator ignition parts, doesn't mean they work. Quote Link to comment Share on other sites More sharing options...
pr0blumz Posted December 3, 2008 Report Share Posted December 3, 2008 No, the voltage regulator is strictly for the lights/tail light. I would definately check your ground first, you need to get an ohmmeter and start testing stuff! What he said. I just went through the same stuff and found my key switch wire had broken loose from the solder joint on the back of the switch. Quote Link to comment Share on other sites More sharing options...
oldskoolracer Posted December 3, 2008 Author Report Share Posted December 3, 2008 JK!!!!!!!!! LOL i will go home tonight and check the wiring a little bit better and set up that extra ground. anything is worth a shot at this point we were going riding this saturday and i dont want to ride my blaster,lol. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted December 3, 2008 Report Share Posted December 3, 2008 Get a tether type kill switch for it. Bypass completely the handlebar on/off switch. Cut the wires. DOUBLE CHECK the tors wires, cut them and tape them apart from each other if you have to. ohm the stator. If your buds have banshees that run, borrow ignition components... If the wiring is good...the most common problem is the Stator, then the spark plug end caps. Stock coils are actually pretty good, but the factory caps blow donkey. Quote Link to comment Share on other sites More sharing options...
oldskoolracer Posted December 3, 2008 Author Report Share Posted December 3, 2008 it does already have a tether kill, it replaced the lock cylinder. the off switch still works. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted December 3, 2008 Report Share Posted December 3, 2008 Without any spark...how can you say that for sure? Cross the wires.. Quote Link to comment Share on other sites More sharing options...
oldskoolracer Posted December 3, 2008 Author Report Share Posted December 3, 2008 very good point Quote Link to comment Share on other sites More sharing options...
