I though I wanted a cub, turns out that I don't. I ride trails and horseshoe drag, these are not for me. I got 68mm stock stroke cub cylinders with a clean up port and a 115mm long rod crank. I also have two sets of used pistons, (usuable), and two sets of 20cc domes. I'm looking for a +4 crank and stock cylinders with no porting and stock bore.
what crank are the cubs for I have a 4mm crank and aset of stock cylinders on thier first bore 64.25
Cylinders are for a stock stroke crank. Also the domes are cut .030 and other set is cut .043. I don't know why, you would have to ask Radarracing that one. I just put in the .030 and ran em.
I have a set of '06 stock cylinders with very little time on them and no porting. I would be willing to make up whatever you thimk the difference is in cash........... What do you think?
  • 1 month later...
