chadj1980 Posted November 27, 2008 Report Posted November 27, 2008 Nt banshee is stuck in 4th seems like it shifts up but insnt, doesnt go down lever is also up higher than normal....anybody got ideas Quote
firebanshee Posted November 27, 2008 Report Posted November 27, 2008 Nt banshee is stuck in 4th seems like it shifts up but insnt, doesnt go down lever is also up higher than normal....anybody got ideas Maybe the bolt broke off that goes through the spring on the shift shaft.If the shift lever doesn't have any spring action up or down this could be the problem,i have broken a few of them myself. Quote
chadj1980 Posted December 7, 2008 Author Report Posted December 7, 2008 finally gonna chance to see what's wrong... it feels like it shifts but isn't and you have to manually put the lever back to a nut.. position...anymore ideas before i start ripping it apart...makes the normal ckicking noise when you try to shift it... Quote
killshee Posted December 7, 2008 Report Posted December 7, 2008 just fixed mine ....pull off the clutch cover and check peg between spring if its broke pull clutch (32mm) i think and then pull starter gear and get the old peg out and make a new one it should thread out like a bolt.... Quote
