tundish2800 Posted November 26, 2008 Report Posted November 26, 2008 Is there any mods to the cover if you use the slingshot style from herr? trying to look as stock as possible. Quote
gregrob Posted November 26, 2008 Report Posted November 26, 2008 No mods to the cover at all afaik Quote
KaosBanshee44 Posted November 26, 2008 Report Posted November 26, 2008 If you use a stock clutch cover i believe you have to grind the knubs on the inside "as in the knubs for the clutch cover insert screws" But i could be wrong Quote
KaosBanshee44 Posted November 26, 2008 Report Posted November 26, 2008 Yep i was right, scroll down a few and someone ask about the grinding off the nub part http://forums.atvdragracers.com/index.php?...c=113&st=20 Quote
tundish2800 Posted November 26, 2008 Author Report Posted November 26, 2008 thanks for the link Quote
2001Stroker Posted November 26, 2008 Report Posted November 26, 2008 I read on here a couple weeks ago, that there are two different size Slingshots for Banshee's. Whoever it was, said that one needs machining, and the other doesn't. I don't know personally, but I did read that on here. And yes, it was from someone reputable. I think it was Kawiking or dajogejr that said that. Could be wrong though. Quote
