atvfreestylekid Posted November 24, 2008 Report Share Posted November 24, 2008 My first question is if anybody knows if a set of dmc 916 mid-pipes and muffler will work with T5 headers? I also need to know if a trinnity 2-1 carb will feed my stroker with the listed mods in my sig. Thanks. -Josh Quote Link to comment Share on other sites More sharing options...
278 Posted November 24, 2008 Report Share Posted November 24, 2008 The 2 into 1 set up will feed it go with like a 35 mm carb or bigger, probably bigger but yeah it will. As far as the silencer, anything will fit... sometimes it takes a little modfiying and creativity :biggrin: Quote Link to comment Share on other sites More sharing options...
atvfreestylekid Posted November 24, 2008 Author Report Share Posted November 24, 2008 The 2 into 1 set up will feed it go with like a 35 mm carb or bigger, probably bigger but yeah it will. As far as the silencer, anything will fit... sometimes it takes a little modfiying and creativity :biggrin: Ok. Thanks. My friend gave me a 2-1 kit that needs a needle, slide, cable and top. Just making sure it will be enough before I buy the stuff. I'm about to start MX and heard the 2-1 is better for it. you think i should go with the single or keep the dual 28's? Thanks. Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted November 24, 2008 Report Share Posted November 24, 2008 Keep the dual 28's. The only thing that will make the single better is the fuel sloshing you will get in the duals. Quote Link to comment Share on other sites More sharing options...
278 Posted November 25, 2008 Report Share Posted November 25, 2008 Yeah I'd stick with the 28's, cuz you don't have to buy anything, and there really wont be much difference Quote Link to comment Share on other sites More sharing options...
