sycopyroclown00 Posted November 24, 2008 Report Posted November 24, 2008 ive got 2000 shee that i lost a crank bearing and it wrecked the case so im going to part it out i dont have the money to fix it need money for my girls engagement ring bike ran a 13.1 when the crank bearing went best run of 12.9 at 96 mph before the port work or the carbs everything is for sale i will post as many pix as i can im located in Pennsylvania 19403 near Philly whole motor minus the case jugs are stock bore drag ported by bansheeboyz racing in Alabama two heads one stock and one is milled and rechamberd 15 each 2 sets of reed cages somewhat ported 35 each set set of stock intakes with everything but the air box 15 34 mm billet intake by boss racing has boost bottle 100 stock crank needs outer bearings 50 clutch basket w/ everything 50 crank gear ? American racer front tires 18-6-10 i think 200 American racer rears 20-10-10 only 10 runs max brand new on new wheels balanced 350 10 inch extended swinger stock style 75 34mm pj carbs 170 with throttle cable a set of drag jetted stock carbs with cable 65 trans 175 rocket pipes exhaust 175 thumb throttle levers perches kill switch handle bars 50 the whole bike is going i cant type everything let me know what u need i probably have it [email protected] 610-476-6778 will post more photo's these are the best 2 i have on my laptop Quote
06shee325 Posted November 24, 2008 Report Posted November 24, 2008 I cant believe a bike built like that is only 13s, Btw nice bike i dno if id part it out. how much for everything? Quote
