i was talkin to a buddy and he brought up somethin about bein able to mickey mouse your stock timing plate to enable you to advance the timing. i just baught an sdjustable timing plate and now im wonderin if i could have just modified my stock one and still gained the same amount of performance out of it?? what do you guys think?? :unsure:
yes the bolt holes can be slotted to give you+ 4. keep the adjustable plate. who`s to say all your bike needs is+4. it may run better with more timing.remember more timing = more heat. check your plugs.
Yep, sure can. I modify mine on a bridgeport with a rotary table and can get 5 degrees advance. If you take your time and do it carefull, you can do it with a dremel tool.
