I have stripped my stock wheels of the gold anodizing, and have bare aluminum that needs some mild abrasive work before polishing. What is a good product that uses a die grinder that can lightly sand with 120 grit or finer that I can use to get these wheels in better shape? Thanks.
Ok, I will reply to myself for those that might want the information.
HOW TO REMOVE GOLD ANODIZING AND POLISH STOCK WHEELS:
Needed:
degrease
easy-off oven cleaner (Heavy Duty)
paint stripper
41/2 angle grinder
die grinder
polishing disk for grinder
polishing ball for die grinder
extra heavy duty polishing rouge
wire wheel (fine) for die grinder
120 grit or finer padle wheel for die grinder
Fine scotch brite pads
time
1. degrease wheels
2. if painted, strip paint by applying stipper, let sit for 10 mins, wash with warm water and repeat if needed
3. apply thick coat of easy-off and let sit for 30 min or more (you can let sit over night if you like)
4. remove with warm water and scrub brush
5. remove anodizing with die grinder and wire wheel (the gold color will remain after the cleaner, but the wire wheel will remove it very very fast)
6. Sand entire wheel surface with the die grinder and paddle wheel
7. smooth surface with the scotch brite pad
8. use angle grinder, buffing wheel and rouge to polish the wheel to a nice shine
9. use the die grinder and polishing ball for those hard to reach areas
10. drink a beer cause that was alot of work, but man, do they look good
Pictures fo follow.
Needed:
degrease
paint stripper
41/2 angle grinder
die grinder
time
1. degrease wheels
Pictures fo follow.
why not just bead blast them
Here is the finished product. I didn't go nuts with the wheels. I did what I would call a "trail polish". No sense going nuts just to beat it off of trees and rocks. But it looks much better than crappy rattle canned wheels, that it was when I bought it.
Edited by regalrocket
They were the factory gold anodized, that was then spray painted black by the previous owner. So i removed the paint, the anodizing, then polished. I am happy, looks way better than rattle canned black, or the factory gold.
