ok this is what i got: 02 shee with 4mill long rod, matched aggresive trail/hillshooter full port job, case matched, t5 pipes, 28mm carbs, cool head pushing 172-174psi, dyna tek cdi on curve 3, adjustable stator +2, v force 3, open air box, 15-41 gearing with stock swingarm, extended arms and 21's on the rear tires................................would like to know what i need to do to hook up and get some good traction.......i ride in a lot of dirt trails open and tight and coal hills and fields....alot of head to head racing on those surfaces too......so what do i got to do.....gearing, swingarm, what! help me here
I'd say if your having traction problems go with some 22's out back then drop your rear sprocket
6 ply kenda .....i think knarly's
if you ride like me, then you gotta learn to plant your ass more often, and further back. then have someone ride like you, and watch the tires to decide if they can hold the bead and take the abuse with lower air pressure. i also braapp the throttle alot to get a better bite. bbrrrappp, ba brappp brapp bra- ving ving ba brapp brap ving wheeeeeeeeeeeeeeeeeeee!!!!!!! :woot: i'm using 22-12-10 bear claw's makin' love to da ground, but i gotta skinny up for the soft shit. wish i could find some good 24-9-10's on rim's
