that would look bad ass i agree. hopefully someone has tried this setup before.. if not my buddy has a 450 thats down for repairs right now i might have to snag his temporarily, see if it works out!
now ive never had a yfz apart, but the honda and along with 90% of other four wheelers it seems like the rear motor mount bolt is also the swingarm bolt. If this is true i don't see it working..
well i guess you could make a spacer and put in there. :confused:
Right...the swingarm bolt goes through the motor (makes it even more fun to work on a #!$$!#@!# YFZ)...I would think a spacer should make it work as long as the width is the same.
not happening. the banshee and 450 linkages are totally different. the 450 linkage mounts underneath the swingarm and the banshee linkages mounts on top. they are two totally different setups.
you'd be better off with a raptor swinger, they look the same as the yfz , but fit better, imagine the banshee swinger, but the shock mounts where the dogbone attatches. you could remove the air bbox and change the spring, make a dog leg link, or cut, and weld a box into the swinger to clearance the link. you may have to pickup some pipe stock, or cut & weld the pivot from the banshee swinger to mount it. if you or someone you know is handy with a welder, it shouldn't be a problem, and the mods and welds, are in inconspicuous spots, so as to not change the appearance. the swinger is a little longer, and heavier though. not by much, just a heads up :thumbsup:
p.s. get pics, or i will send seven stealth assasins :ninja: :ninja: :ninja: :ninja: :ninja: :ninja: :ninja:
