1.6i Posted November 19, 2008 Report Posted November 19, 2008 So my buddy blew his engine in glamis halloween weekend..long story short he went and bought some 34mm keihin carbs online (dont know what model yet) and we need some base line start on jetting.. mods are as follows: 34mm carbs assuming pwk's not sure yet pods wiseco 65mm bore/stock crank cool head 21cc domes fmf fattys timing @+2 V-force 3 stock port sea level are these carbs too big for his setup? where should we start the mains, pilots and needles at? i only have experience with stock carbs so far..so i need some schooling thanks in advance Quote
jbooker82 Posted November 19, 2008 Report Posted November 19, 2008 Yea I would say they are to big for a stock ported machine. I would get a port job instead of getting rid of the carbs. You kind of need to know the moddle of the carb because PJ's and PWK's do jet a little different. I will assume they are PJ's since they are 34mm. Your really going to need a carb sync tool because you set the Idle by turing the choak knob. I would start out in the is range. main 155 needel CEK middle clip pilot 50 or 48 When I had PJ's before my PWK's the PJ's seemed to like a little richer bottom end. If your going on a trip I would probably take main jet sizes 158-148 and pilot jet sizes 52-45 and a pair of CEK and CEL needles. josh Quote
1.6i Posted November 19, 2008 Author Report Posted November 19, 2008 ahh i see...ima head to his house today to see what we're working with and then go from there...thanks for the info its gonna be useful for a base start Quote
jbooker82 Posted November 20, 2008 Report Posted November 20, 2008 Here is some really good info on Keihin Carb jetting too. http://www.duncanracing.com/techfaq/Tech_k...n-jetting.phtml Quote
1.6i Posted November 20, 2008 Author Report Posted November 20, 2008 this guy, i was at his house earlier and turns out he bought mikuni 34MM carbs :geek: any thoughts or input on these? Quote
1.6i Posted November 21, 2008 Author Report Posted November 21, 2008 should we start at like 350's?? Quote
jbooker82 Posted November 21, 2008 Report Posted November 21, 2008 I have no idea. Never jetted a mikuni carb on a banshee. You might be better off making a new post with the correct carb in the subject. Quote
