I ride mainly trails. I have about 200 bucks to spend. I currently have fmfs fatties, a no name port job, bandit xc tires, k and n pods, +4 timing. What should I do with that $200? Try to get some used t-5's?, some differnt carbs, better shocks?
Edited by jugriggs
Look into an aftermarket head with 20 or 21cc domes.
For that amount of $$ look for a Cool head or some V force reeds in that order.
Forgot to mention Im running a coolhead 22cc domes, doesnt really seem to do anything/compared to running a milled head at .30. So I will definatly notice a increase in performance with v2's or v3's?
I've got to tell you man, many people say get some VF's, but If you get them ported properly and put the right petals on there, I personally like the dual stage carbon petals... it will do just as well if not better than VF's and in most cases they will flow better!
He's already got a coolhead, and jugriggs when ever you need to take your head off I would invest in some 21cc domes. Another thought would be the keihin 28s or the 30mm oko's which I have and love em. In my opinion the carbs was one of the best upgrades for the $$ on my bike.
22cc is the same size as stock I believe.
Put some 20's or 21's and you'll notice a difference. I think 20 is the lowest you can go on pump and you'll be pushin 155psi give or take.
Yea since you have some port work done you could prolly get by with 20s since porting usually drops compression alittle. I'm runnin 21s and have 150psi per cyl. with no porting.
