bbcmudtruck Posted November 18, 2008 Report Posted November 18, 2008 What all is involved in putting the yfz 450 brakes on the front? Does it help enough to put them on? Quote
Trick2stroke Posted November 18, 2008 Report Posted November 18, 2008 They just bolt right up, you may want to use a different lever to push more fluid to the dual piston caliper, either the yfz or trx450 lever but it's not nessicary, just makes for more responsive brakes. There are advantages to using the whole set up but the calipers will just bolt on to the banshee spindles. Quote
4stroker Posted November 18, 2008 Report Posted November 18, 2008 really?? that is awesome if they do, i have been wanting to upgrade my brakes ever since i rode my friends KTM 450 quad, you could do stoppies on that thing easy! is there any advantage to using the disc too? (if it can be used) thanks, mark Quote
