BklynLOD Posted November 17, 2008 Report Posted November 17, 2008 Is there anything you guys use to get rid of rust?????? Quote
XxMeltIcexX Posted November 17, 2008 Report Posted November 17, 2008 Sandblast and PC, never have to worry bout it. Quote
2001Stroker Posted November 17, 2008 Report Posted November 17, 2008 if you're just trying to kill it, Ospho. It kills rust and primes it. It's a green liquid. You have to wear dish washing gloves and preferably a mask when you use it. It will burn your skin and singe your nose hairs. Quote
ny98banshee350 Posted November 17, 2008 Report Posted November 17, 2008 if its small spots get a wire wheel brush that will fit on a cordless drill and go 2 town..then spray with paint or do what most ppl do(including myself) tear down ur whole shee and do a complete rebuild and get it pc'd Quote
T_Shee Posted November 18, 2008 Report Posted November 18, 2008 or if you dont wanna drop a bundle on pc. sand the rust down and paint with this. http://www.kbs-coatings.com/index.html. you can shoot it with a spray gun or just brush it on and the streaks go right away. ive used it a ton and i highly recommend it Quote
T_Shee Posted November 18, 2008 Report Posted November 18, 2008 all you need is the rust seal paint. im sure the other stuff would work too but not necassary Quote
BansheeRider87 Posted November 18, 2008 Report Posted November 18, 2008 After reading this topic i remember using something but don't remember what its called... It came in a oil stablizer jug like Lucas.. and you painted it on with a brush and it would go on like white Elmers glue and after it dried it would turn the rust blue and be clear primer and you could paint right over it... Any ideas id like to get it again Quote
Blaze04 Posted December 7, 2008 Report Posted December 7, 2008 Depending where the rust is, I know that if it's on like chrome, I used S.O.S pads to take small to medium size spot of rust on my header pipes. Quote
PACIFIC NW BANSHEE Posted December 8, 2008 Report Posted December 8, 2008 Try por-15 works great used on alot of old cars turns black dont have to do anything after you paint it on you can leave it black like a paint and never touch again good luck Quote
wayfast1500 Posted December 8, 2008 Report Posted December 8, 2008 I've had good luck with naval jelly. Quote
kubitza123 Posted December 11, 2008 Report Posted December 11, 2008 Best stuff i have ever seen is called RUST CURE it basically pull the rust out of the metal and even leaves it primed afterwards so you can lightly sand it and spray it Quote
