plumcrazy73dodge Posted November 16, 2008 Report Posted November 16, 2008 Stock set - up going to paul turner Mid ranges w/fat boy silencer Timing advanced 5 What is a recommended jetting for that application Is there a tutorial on how to jet? Mike Quote
elwilliams13 Posted November 17, 2008 Report Posted November 17, 2008 I got the midrange PT's and I am at see level with an agressive trail port 4mil. I plug chopped down to 260main and it runs great with a dark brown 360 degree ring at the base of the plug. So you should be from 260 to 300 if you are at sea level. Quote
plumcrazy73dodge Posted November 21, 2008 Author Report Posted November 21, 2008 I got the midrange PT's and I am at see level with an agressive trail port 4mil. I plug chopped down to 260main and it runs great with a dark brown 360 degree ring at the base of the plug. So you should be from 260 to 300 if you are at sea level. I am at about 500 ft above sea level at home and do some riding in upstate NY- unknown what altitude.. Quote
