sheemen14 Posted November 14, 2008 Report Posted November 14, 2008 i went to start my shee after i had put a new fuel filter in it, i kicked for a while and stopped and heard a stream of gas hitting the floor, i look down and gas was pouring out of the carberators overflow tubes(the ones that come from the bowl) i pulled the carbs of to make sure they were clean and everything was fine.....whats the problem? please help if anyone can it will be much appreciated Quote
BansheeRider87 Posted November 14, 2008 Report Posted November 14, 2008 i went to start my shee after i had put a new fuel filter in it, i kicked for a while and stopped and heard a stream of gas hitting the floor, i look down and gas was pouring out of the carberators overflow tubes(the ones that come from the bowl) i pulled the carbs of to make sure they were clean and everything was fine.....whats the problem? please help if anyone can it will be much appreciated floatsssss stuck :thumbsup: Quote
AKheathen Posted November 14, 2008 Report Posted November 14, 2008 floatsssss stuck :thumbsup: ditto :wink: needle and seat would only cause a drip Quote
sheemen14 Posted November 14, 2008 Author Report Posted November 14, 2008 i agree with you guys..... i pulled the bowls off to make sure everything was good and everything looked good but hmmm looks like ill be going to work on some carbs. FUN! Quote
