sheemen14
Everything posted by sheemen14
  1. i agree with you guys..... i pulled the bowls off to make sure everything was good and everything looked good but hmmm looks like ill be going to work on some carbs. FUN!
  2. i went to start my shee after i had put a new fuel filter in it, i kicked for a while and stopped and heard a stream of gas hitting the floor, i look down and gas was pouring out of the carberators overflow tubes(the ones that come from the bowl) i pulled the carbs of to make sure they were clean and everything was fine.....whats the problem? please help if anyone can it will be much appreciated
  3. its good to see some fellow drummers as well as riders with good taste in music....i also have a premier and its pretty sick for its price
  4. do you still have the nerf bars/ heel gaurds?
  5. thanks a lot guys... it sucks when your on a sand flat and you can't do anything because water got in your engine, it was a long day...
  6. yeahi mostly ride at st joes in missouri which is always wet, and its hard when your flying in 6th gear and have to slow down to go through a stream of water
  7. Thanks a lot looks like I'm going to be doing some welding
  8. the only after market box i can find is the um air box, the guy we bought the bike from didn't have the stock air box and had a 2 into one filter...this thing needs a box bad, should i try to find a stock box or go for the after market????????
  9. i have a 2 into 1 filter with no box what so ever and that is no good considering i ride around water, i was looking online for an aftermarket box to buy and it looks like UM is the only ones that i know of that make a box. does anyone know if there any good?
