wacko2000 Posted November 11, 2008 Report Posted November 11, 2008 I need to order new shifting forks and shifting drum. When i look on like bikebandit.com or something i cant seem to find it. Is it called something else? So where can i buy a shifting drum? thanks Joseph Quote
2001Stroker Posted November 11, 2008 Report Posted November 11, 2008 I need to order new shifting forks and shifting drum.When i look on like bikebandit.com or something i cant seem to find it. Is it called something else? So where can i buy a shifting drum? thanks Joseph I just seen a shifting drum on eBay that Minkia38 is selling. Quote
Screaming Yellow Zonker Posted November 11, 2008 Report Posted November 11, 2008 stock replacement is SHIFT CAM ASSY part # 2GU-18540-00-00 Quote
clinton588 Posted November 11, 2008 Report Posted November 11, 2008 I need to order new shifting forks and shifting drum.When i look on like bikebandit.com or something i cant seem to find it. Is it called something else? So where can i buy a shifting drum? thanks Joseph Call Alba action in CA. they have a shift drum with a bearing on the inside support, makes the drum turn easy. You can also get the forks from them. Quote
wacko2000 Posted November 11, 2008 Author Report Posted November 11, 2008 Call Alba action in CA. they have a shift drum with a bearing on the inside support, makes the drum turn easy. You can also get the forks from them. Kool thanks. I pretty much ordered everything in that picture..lol Quote
