POORBOY350 Posted October 28, 2008 Author Report Posted October 28, 2008 thanks everyone! i think i got it. still feels lil hard to pull but i guess its from the lockout. i will know tom if its adj. right. Quote
KaosBanshee44 Posted October 28, 2008 Report Posted October 28, 2008 Aftermarket pushers sit behind the pressure plate and the stock one is actually atatched to the plate. Quote
2001Stroker Posted October 28, 2008 Report Posted October 28, 2008 OK.. why would there be 2 diff kind of springs in there? looks like 3 heavy duty springs and 3 regulars its causing one side of the clutch to disengage before the other side? wtf! ? If you have 3 of each spring, every other one should be an HD. Quote
POORBOY350 Posted October 28, 2008 Author Report Posted October 28, 2008 mine wasnt attached to the the pressure plate so it might be aftermarket. it was sitting behind it. and the springs were on each side of the clutch but it was making one side disengage first so i put them every other one. i think i got it right lol. Quote
Hilarious Posted October 28, 2008 Report Posted October 28, 2008 IT has the 12mm nut with a allen head screw inside of it. that right there tells me you already have an aftermarket adjuster in there. i know the ones cascade sell have an allen screw, which is the one that i have. mine wasnt attached to the the pressure plate so it might be aftermarket. it was sitting behind it. and the springs were on each side of the clutch but it was making one side disengage first so i put them every other one. i think i got it right lol. sounds like you put it back together correctly. Quote
POORBOY350 Posted October 29, 2008 Author Report Posted October 29, 2008 sounds like you put it back together correctly. NO... i dont think i did. idk what i did. i had to take it all bak down and fix the kickstart(had to load the spring) but now i slowely turned it over with the kickstart just to see if it was working. and it makes a terrible screetching noise when i turn it over slowely. i can feel it almost. have no idea what it is. i do think i put anything bak wrong wasnt much to mess up in there i didnt put any oil in it yet cause i didnt wanna have to drain it and get more so i just barely moved the kickstart with my hand to make sure it wasnt still making this noise(cause i thought it was smtn to do with the kickstarter)but it still is>>>. any ideas.....???? Quote
