rla_banshee Posted October 23, 2008 Report Share Posted October 23, 2008 please i need help weather or not to do the rebuild right now thanks Quote Link to comment Share on other sites More sharing options...
hylander88 Posted October 23, 2008 Report Share Posted October 23, 2008 please i need help weather or not to do the rebuild right now thanks I would check spark...the gap on the stator pick-up...first . Not enough spark would be one reason for hard to start. and how is you compression Quote Link to comment Share on other sites More sharing options...
dragbanshee Posted October 23, 2008 Report Share Posted October 23, 2008 please i need help weather or not to do the rebuild right now thanks Did you do a compression check yet? Did it just start doing this? you need to give some info if you want help. Quote Link to comment Share on other sites More sharing options...
rla_banshee Posted October 23, 2008 Author Report Share Posted October 23, 2008 Did you do a compression check yet? Did it just start doing this? you need to give some info if you want help. no comp test, my kick start has play doesnt catch up top grabs about middle, has plenty of spark ouch i know , its getting fuel, havent synced carbs yet though i switched back to dual from homemade single setup Quote Link to comment Share on other sites More sharing options...
1996dragshee Posted October 23, 2008 Report Share Posted October 23, 2008 u should pull that clutch cover off and see exactly why your kicker gear doesnt grab at top... Quote Link to comment Share on other sites More sharing options...
dragbanshee Posted October 23, 2008 Report Share Posted October 23, 2008 And do a comp. check so you can narrow down the possibilities. Quote Link to comment Share on other sites More sharing options...
rla_banshee Posted October 23, 2008 Author Report Share Posted October 23, 2008 And do a comp. check so you can narrow down the possibilities. deff gonna do those 2 things tommorow afternoon please check for updates thanks! Quote Link to comment Share on other sites More sharing options...
AKheathen Posted October 27, 2008 Report Share Posted October 27, 2008 deff gonna do those 2 things tommorow afternoon please check for updates thanks! definately lack of full swing. the air just isn't mooving fast enough to get it started at half swing. mine starts first or second kick sitting down warm, but i have to stand up holding the choke out and kick it 4-8 times fast @ 30-40 degrees when the engine cold. i wouldn't put up with the frustrations of a half kick :verymad: Quote Link to comment Share on other sites More sharing options...
