Help is greatly appreciated.... and I thank you all in advance.
I have a 99 banshee...
I have just put on
High rev cdi box stage 2
v force reeds & cages
Engine is bored to 80mm over
Single carb air filter
Stock voltage regulator
Stock ignition coil
namura pistons
What I really need to know is with all those things recently added, What size jets do i need to be added? I have been having some minor problems with the shee, carbs overflowing and such (i posted about that on another thread) but i wanted to be more specific in here in hopes to get an answer. I appreciate it.
:banghead: This is getting fustrating as I'm not sure what to do next...
:huh: What size jets do i need to be added?
Nobody can tell you anything without knowing a few basics. What size and brand carbs? what pipes? whats the elevation where you are at? And it will only be close. There is tons of info on jetting already on this site, just gotta find it!
what sin said.
also a wild guess but if your carbs are leaking gas threw that overflow tubes. id take a stab and say your floats inside the carbs arent adjusted right or rising to stop the fuel flow from shutting off.
what sin said.
Thanks, i appreciate it.
