rla_banshee Posted October 13, 2008 Report Posted October 13, 2008 i found these two diagrams and wondering how i get from the first harness to the second do i use all new wire? where do i set up grounds!>? please any help would be appreciated! Quote
jbooker82 Posted October 13, 2008 Report Posted October 13, 2008 What are you trying to do. By the looks of the wiring diagram they just cut some of the wires and switches out, and wired it so the high beams would be on all the time when ever it is running. Quote
rla_banshee Posted October 13, 2008 Author Report Posted October 13, 2008 What are you trying to do. By the looks of the wiring diagram they just cut some of the wires and switches out, and wired it so the high beams would be on all the time when ever it is running. And how did you go about doing that? My lights don't work at all Quote
Snopczynski Posted October 13, 2008 Report Posted October 13, 2008 And how did you go about doing that? My lights don't work at all You need to get a meter and or a test light and fix your stuff first before you go changing it. Quote
rla_banshee Posted October 13, 2008 Author Report Posted October 13, 2008 You need to get a meter and or a test light and fix your stuff first before you go changing it. TEST WHAT? i might just change the whole harness cuz it looks like theres alot of things cut already Quote
Snopczynski Posted October 14, 2008 Report Posted October 14, 2008 TEST WHAT? i might just change the whole harness cuz it looks like theres alot of things cut already Check the lighting wire where it comes out of the stator at the plug in. You need to prod it with a test light until you find where its no longer traveling down the wire? You need some testers to check basic things like bulbs, wire continuity, regulator integrity, etc..... Quote
rla_banshee Posted October 14, 2008 Author Report Posted October 14, 2008 Check the lighting wire where it comes out of the stator at the plug in. You need to prod it with a test light until you find where its no longer traveling down the wire? You need some testers to check basic things like bulbs, wire continuity, regulator integrity, etc..... gotcha thanks ill keep trying Quote
