yfzut Posted October 2, 2008 Report Posted October 2, 2008 (edited) this started life as a 2000 3500 hd 2wd gmc. now after removing about 6 1/2 feet from the frame and tossing the dually axle. then throwing in some 63 inch long rear gm leafs and 56 inch long rear leafs up front. and a d60 front and d70hd rear and a propane 454 and i still need the adpters to install the 4l80e and np205. and it got some new 42 inch iroks and black steel wheels that will have beadlocks installed. my plan now with the cab is tomove the column over and cut the width i need for a jk width body is to cut off what i dont need off each side and the from front grille to back corner is to skin it with 1/8 inch steel. and cut in the door openings and wheel openings and build flares off that. i now have a jk hood and grille. it will have 4 door openings just like a unlimited. its going to look like a much bigger, better and faster version of my 07 jk unlimited, i started this project months ago but couldnt get much done since i only had 1 double car garage, but since i moved i have 2 double cars. so now i can really get rolling. heres some pics to start . it will be completly torn down when done and the frame and axles will be painted black and evrything else will be painted or cleaned Edited October 2, 2008 by yfzut Quote
POORBOY350 Posted October 2, 2008 Report Posted October 2, 2008 NICE! my cousin is building a cj5 right now with a 350 with can turbo 350 trans looks funny with no body its alot of motor for the lil cj5 but thats a good thing. Quote
yfzut Posted October 6, 2008 Author Report Posted October 6, 2008 i got the sides of the cab and cowl cut down. to get ready to skin the sides and put a factory cowl and windshield frame on. Quote
yfzut Posted October 12, 2008 Author Report Posted October 12, 2008 well i cut off the front crossmember and welded one in front of the frame instead of below it. and also moved the front mount forward 4.5 inches. will finish the shackle end tomarrow Quote
2bzy2p Posted October 12, 2008 Report Posted October 12, 2008 sweet I got a few buddies that are into jeeps,nice project! Quote
lilmegill727 Posted October 12, 2008 Report Posted October 12, 2008 (edited) nice. thats gonna be cool when done. arent you doing a shee/yfz hybrid too? Edited October 12, 2008 by lilmegill727 Quote
