The BOSS(wife) just gave me the go-ahead....
so...... this is what i got....
94 SHEE prodesign cool head 18cc domes
FMF gold series pipe
carbon fiber reeds (stock reed cages)
trinity stage 4 2 into 1 carb manafold
PWK 33mm
K&N filter and precharger
shift pro shift kit/ cascade modified star
...this is what im doing....
4mm stroker crank and pistons
drag port stock jugs (mccoys performance)
custom domes (mccoys performance)
dunable overide transmission (mccoys performance)
...this is soon to come....
cheetah cub cylinders
shearer big bore in frame pipes
dual PWK 39mm carbs
lock up clutch
vf3 reeds
thats all just engine. i do have mutch more planned....
FUCKIN' STOKED!
If your planning on doing a cub in the near future, I wouldn't spend the money on drag porting your stock cylinders with new pistons, and custom domes. You will just have to buy new pistons and domes again once you get the cub. Just my 2 cents.
I agree with him, JUST CUB IT NOW!!!! you wont be dissapointed!!!
+3 on the cub now. You'll be throwing good money away drag porting the stockers if you plan on a cub in the near future. Drag porting, boring your cylinders and new pistons will only be a couple hundred shy of the cub price.
This is exactly what I was thinking, you're paying the piper twice.... Nate does a helluva job, but....I'd rather have his cub than a set of stockers...
Did you take into consideration a longer swingarm, shock setup stiffer, longer chain, gearing change AND different paddles/tires?
Just trying to help you complete the package...:)
sure ill sell that 2 into 1... as soon as i get me new carbs...
what sparked this whole thing off was a whole in the piston.... so i have to change my pistons anyway. and the cub cylinders alone are about $899, not ported(from nate) just dont have the money right now for the cubs... do have the money for a port job.
have considered, and will be getting a new swing arm, chain and paddles. as of now, im running an 8 paddle.
will be getting shearer big bores, as original post states. all in due time.
Don't ever get married, then you wouldn't have to ask to go take a shit when you need to much less buy parts for your bike.
GEAT ADVISE! everyone listen to this man!
