lt1bird Posted September 20, 2008 Report Posted September 20, 2008 (edited) LOL cant get the main drive gear nut off...got the clutch basket bolt off with the impact gun....but the main drive gear nut is not budging. Holding the flywheel super tight.....impact gun on the nut and its not coming off. It does come off Counter clockwise? Had to ask as the manual does not say.... Any hints??? Edited September 20, 2008 by lt1bird Quote
lt1bird Posted September 20, 2008 Author Report Posted September 20, 2008 Nobody has taken off thier main drive gear bolt????? CCW correct??? Quote
LiftdT4R Posted September 20, 2008 Report Posted September 20, 2008 This place is dead today.... When you say flywheel, your not talking about the electrical flywheel are ya? Quote
lt1bird Posted September 21, 2008 Author Report Posted September 21, 2008 No, the gear at the end of the crank shaft......its held on by a nut......Ill try heating it with a torch..... then impact it..... Quote
lt1bird Posted September 21, 2008 Author Report Posted September 21, 2008 These things are so easy to work on.....All you have to do is this... 1) Put breaker bar on bolt...very long one.... 2) Put flywheel holding tool on flywheel 3) Put engine on ground 4) heat the bolt with a torch 5) Stand on top of the f-in engine 6) Hit the breaker bar with a small sledge hammer........off it comes....simple.... now to split the case....god help me Quote
sandman Posted September 21, 2008 Report Posted September 21, 2008 Took mine off today as I'm getting ready to send my crank out to get it welded... it is a normal righty tighty, lefty loosey. Mine came off with an air gun. Best of luck. Quote
lt1bird Posted September 21, 2008 Author Report Posted September 21, 2008 (edited) I figured that...really didnt care anymore id it borke Nice to see that another zo6 owner is into two strokes Edited September 21, 2008 by lt1bird Quote
