f4istunna Posted September 20, 2008 Author Report Posted September 20, 2008 Heres a list of most of the stuff. I have several boxes of spares left too that i still have to go through. I know theres another set of a arms, swingarm, shocks, etc. Cylinders/Pistons SOLD Pipes/silencers SOLD Bottom end cases, trans, crank etc Everything inside cases $400 Case broken at normal spot no leaks -Radiator $25 -Rear shock (white) $45 -front shocks (white) minor paint wear from covers $25 -thumb throttle $20 -Ignition switch w/ key and dash peice (dash plastic scuffed) $15 -Never used oem bumper $20 -used oem bumper $5 few dings - Front hubs w/ rotors rotors straight $45 -pipe hangers $10 -Clutch lever w/ cable (a/m) $5 -Set of 4 oem a arms nice shape good joints blue $100 -tie rods w/ ends -Spindles $20 -Front brakes Calipers, lines and master w/ lever $55 has like new pads -Rear brakes Caliper lines master w/ resi and lever $55 will need pads -Rear brake hub w/ rotor $25 rotor straight no abnormal wear - f&r sprockets w/ rear sprocket hub $20 -Axle carrier $35 bearings still felt good but have some hours -Oem swingarm blue straight $35 -Headlights $15 some scratches on lens but both worked good last time i remember using them - Headlight/kill switch $20 -Oem steering stem w/ stadard bar clamps $35 straight -Axle (small bend at end on brake side) I used it as is all season, only noticed on the roads $10 if anyone wants it -Seat w/ new gray cover pan and foam good $45 -white plastics front cut blue hood and tank cover $75 no cracks -Stock intake/airbox w/ lid w/ K&N filter $35 filter used but still some life left -Carbs tors eliminated $40 -Oem grab bar w/ tail light Some minor wheelie wear straight no cracks $10 -Stator $40 (red/white wire pulled out of connector) I just used an inline crimp but could be repaired in if wanted the end is still there -Oem flywheel minor surface rust in spots, few dings on the lip Didnt seem to affect anything the bike ran awesome $30 -Reeds w/ cage and xover tube $25 (not sure brand got them w/ quad , good working shape) -Complete Clutch $45 basket/ gear on out w/ bolts springs etc. Clutch worked great no slipping or abnormal noises. Basket showing a little wear aswell as fibers but still plenty of life) -kicker lever good splines $20 Im sure i skipped or forgot some stuff feel free to ask if you dont see it wheels/tires I have alot ill be adding over the next cpl days. Im gonna clean my shed and garage out of some of the extra wheels and tires Douglas polished 8" yam rear $85 W/ 85+% 20" holeshots $120 Oem front yamaha wheels normal lip scuffs/dings $60 All parts will be shipped by next business day after payment made. Paypal or money orders. Thanks Quote
HAUSERSMOTORSPORTS Posted September 20, 2008 Report Posted September 20, 2008 ok. also i need the front bumper. the one that you say is new. Quote
f4istunna Posted September 21, 2008 Author Report Posted September 21, 2008 $50 shipped for all? Let me know thanks Quote
f4istunna Posted September 22, 2008 Author Report Posted September 22, 2008 u do paypal? sure do. I sent you the address Thanks Quote
f4istunna Posted September 22, 2008 Author Report Posted September 22, 2008 Last chance before Ebay!! Gonna start listing tomorrow sometime Quote
mpwrd3 Posted September 23, 2008 Report Posted September 23, 2008 Got the cyls today, everything looks good! Thanks a lot!!!! Quote
f4istunna Posted September 23, 2008 Author Report Posted September 23, 2008 no problem brother thank you!! Quote
specialized Posted September 23, 2008 Report Posted September 23, 2008 Hey im very interested in the lights. i want to put them on a blaster. haha i had to go through all the sign up just to message you. Quote
Mjv420 Posted September 23, 2008 Report Posted September 23, 2008 You still got the stock head? No pitting in the domes? How much shipped? Quote
rigidshee444 Posted September 23, 2008 Report Posted September 23, 2008 You still got the stock head? No pitting in the domes?How much shipped? If you decide to part out bottom end, i want the stator and flywheel if price is right. Quote
f4istunna Posted September 23, 2008 Author Report Posted September 23, 2008 specialized i replied to your PM sent you an email MJV yep still have the stock head. One dome has some very very minor pitting in it. Bike ran great. Ive seen and used heads in way worse shape. Shipping will be $10 or less in the 48 states Pm me your zip and i can get an exact quote Rigid Ill be splitting the cases today. Flywheel and stator are already off though. Flywheel has some nicks in the lip but worked great for me, lights and everything worked as they should. One wire from the stator (red/white) is wired straight in instead of plug but the end is still in the plug and could be repaired fairly easy if wanted. I just never bothered since it was connected good w/ inline crimp. let me know guys Quote
Jer_89shee Posted September 23, 2008 Report Posted September 23, 2008 PM sent on a bunch of stuff Quote
f4istunna Posted September 30, 2008 Author Report Posted September 30, 2008 Alot ending on ebay tomorrow. Ill make an updated list. Bottom end is seperated. Good trans, clutch good but some wear, crank, cases (normal damage from chain no leaks). Quote
yamshe Posted October 14, 2008 Report Posted October 14, 2008 pics of used bumper [email protected] Quote
