pm me for more info keihin carb 2-1 manifold all complete cant get it to run right quad boggs in first gear id like a stock airbox again get back to me thanks in advance
what size is the carb? was it new when you installed it?
Is the carb set up one you put together or a trinity. Not that it matters. Just trying to gather you info to help.
What size carb is it? I have had a 38mm which works fine, I have had 36mm carb which works fine and a 35mm which aslo worked fine as well.
How clean was the carb.
What jetting do you have.
Have the jugs been ported?
Have the jugs been bored?
What kind of air filter are you running?
Open air box or closed?
Has the head been milled or is it stock?
What grade of gas are you running?
Again, not that it matters, but it might?
Don
Edited by pcduc64
Don
i recently bought the quad as is it looks put together nice mani carbs a keihim deff not a trinity i need to get pics next time im in the garage someone told me could be a wrong pilot jet. also i dont have a filter on it now could that make a difference maybe sucking to much air and not enough fuel?
pm me and I will give you my phone number. I have set up 3 banshees with single carbs.
idk if i want to deal with this i think id rather have a stock setup being that this is my first banshee theres also a dyna fs comp on it dont know if i want that either!
i took it to the trails today it rides great carbs a 32 mm keihin carb mint i think i need a cable because it wont idle gotta hold the gas would the dual carb be worth changing back> maybe need a new jet help id rather not part with it but if i have to i will
I wouldnt go back to stock. and if you ride long periods of time i'd imagine that the single would be alot more forgiving than the double right? but hey if you want 2 stock carbs for ur single i got some. i pm'd you.
