Everything posted by pcduc64
Hurting for cash to pay off car.
pcduc64 replied to pcduc64's topic in For Sale - Parts & Accessories
Still have these for sale. $3800.00 They are good buy. Time is running out. http://indianapolis.craigslist.org/mcy/966844604.html -
They can be viewed here.. http://indianapolis.craigslist.org/mcy/966844604.html -
Come on guys, Someone make me some offers..... -
They are on craigslist. I have had them on ebay. I had them listed together and in one day it went up to 2200.00. Then ebay kicked off my auction saying that I could not list them together. http://indianapolis.craigslist.org/mcy/966844604.html -
I would part these out but don't have time to do so. I have been told that I could twice the amount that I need, but my time frame is too short. -
Model: 2000Yamaha Banshee 350 1996 Yamaha Banshee 350 I have a 2000 banshee with Lots of aftermarket that I will attempt to list. A 1996 red and white banshee with some aftermarket. Both quads are in excellent condition. Both run strong, and pull hard. I will give a bill of sale for both quads. Kelly blue book for the 2000 is $2720 without any aftermarket. The aftermarket for this quad alone would equal or exceed the kbb value. Kbb value for the 96 is $2240.00. The 96 does need to have the front suspension bushings replaced. I put a new clutch in it. However it needs the cushion ring for the clutch pack. It did not have them when I bought it. But the rest of the quad is solid. The 2000 needs nothing. Parts include for the 2000 Pro Taper bars, Toomy T-5's pipes and silencers K&N air filter Roll Design A-Arms +2 Dominator Axle +1 Tether Switch Trinity Single Carb cv Manifold System 36mm Carb Aftermarket rims? Rear rims have bead locks Hole shot tires half tread Trinity steal braided throttle cable After market front master cylinder billet cover Aftermarket throttle cover Ricky Stator, Stator unit with adjustable timing. PEP triple rate race shocks After market rear skid plate Stage 5 porting Stock bore Head milled ten thousands Barnet clutch with 20% stronger clutch springs Parts for the 96 Trinity Single Carb cv Manifold System 36mm Carb Aftermarket rims? Stage 5 porting Trinity steal braided throttle cable After market rear skid plate Bored .30 over Barnet clutch with 20% stronger clutch springs FMF gnarly pipes and silencers New sprockets front and back New swingarm bushings E-mail me with any questions @ pcduc64@yahoo.com
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...em=260328845101 Check them out. Lots of aftermarket Don
I forgot to mention that it has stock bore and the intake has been ported.
Goodies include: Pro Taper bars Toomy T-5's pipes and silencers K&N air filter Roll Design A-Arms +2 Dominator Axle +1 Teather Switch Trinity Singlr Carb cv Manifold System 36mm Carb Aftermarket rims? Rear rims have bead locks Hole shot rzr tires Trinity steal braided throttle cable After market front master cylinder billet cover Aftermarket throttle cover Ricky Stator, Stator unit with adjustable timing. PEP triple rate shocks After market rear skid plate
When I saw the photo with all of those banshee's, I got a woody! Do you have any 450's?
This bike has been piped and jetted. VERY FAST!!!. Needs nothing. Ready to ride. This Hurricane has been in my family for years so I know this bike pretty well. Any questions please ask.
Send me a PM
I have a banshee or a quadzilla. PM me.
gauging interest in stock dual carb setup for my single
pcduc64 replied to rla_banshee's topic in Swap and Trade
pm me and I will give you my phone number. I have set up 3 banshees with single carbs. -
Is the carb set up one you put together or a trinity. Not that it matters. Just trying to gather you info to help. What size carb is it? I have had a 38mm which works fine, I have had 36mm carb which works fine and a 35mm which aslo worked fine as well. How clean was the carb. What jetting do you have. Have the jugs been ported? Have the jugs been bored? What kind of air filter are you running? Open air box or closed? Has the head been milled or is it stock? What grade of gas are you running? Again, not that it matters, but it might? Don -
they should be as they come off of the bike stock. I did not remove anything from them.
However, I would make it worth someones trade.
I don't think I would give all of these items for one trade. Well unless theres alot coming back. Ya know.
I will have to look and see if the jets are still in them. They should still be. I have not parted them out. And Yes, they were running. I put a single carb on both one of my banshees. I also have a keihin flat slide 38mm carb that I took off of my 96, it was running when I took it off. The reason I took it off was to put a trinity set up so I could use my airboxes correctly. I have an airstyker 38mm that the idle stop broke. The carb is still in working condition other then that.
I have a pair of jugs that need resleaved.
I have other items. I have two set of stock carbs/with cables. And two boost bottles.
I would like to trade a boost bottle with the mounting hardware for a bearing carrier.
I have a 1990 quadzilla for sale or trade for a 400 or 450 4 stroke?
I have a set of DG woods pipes and two boost bottles with rubber mounts I will trade for a set of a - arms.
Pm or email me. I will trade the carb.
