sheesa350 Posted September 17, 2008 Report Posted September 17, 2008 ok i bought some mobile 1 full synthetic 10w40 4t motor oil it says for systems with wet clutch systems was wondering if i should use this in my trani my buddy uses it in his 400ex an works good clutch grabs nice butt seeing this isnt a 4poke i wanted some input should i use it .. im not using the atf thou seen bad thing from that stuff soo rather not.. and dont liek the bel ray Quote
J-Madd Posted September 17, 2008 Report Posted September 17, 2008 If it says its for a wet clutch, it should be fine. I don't think you actually need synthetic oil, though. I don't think the problem with the Banshee oil is that it breaks down, so much as it builds up clutch fibers and tiny metal fragments. Synthetic may not be any better for tranny oil. Just my opinion. Quote
sheesa350 Posted September 18, 2008 Author Report Posted September 18, 2008 If it says its for a wet clutch, it should be fine. I don't think you actually need synthetic oil, though. I don't think the problem with the Banshee oil is that it breaks down, so much as it builds up clutch fibers and tiny metal fragments. Synthetic may not be any better for tranny oil. Just my opinion. thanx for th input bro.. prolly try it out cant hurt says wet clutch Quote
Ben350 Posted September 18, 2008 Report Posted September 18, 2008 thanx for th input bro.. prolly try it out cant hurt says wet clutch i have always ran Mobil One 10W30 full synthetic in tranny with no problems, was recommended by Vitos Quote
sheesa350 Posted September 19, 2008 Author Report Posted September 19, 2008 (edited) what if i use a thicker weight like 20w50 prolly betta for tranny they have that too Edited September 19, 2008 by sheesa350 Quote
