i saw one on here a while ago now i cant find out who makes them. There a little electic readout that bolts on to the handlebars and the sensor goes into the radiator hose....let me know if anyone knows the make, thanks
I think it was a CJR. For a little more $$ you can get a Trail Tech Vapor. It has
Engine temp, Max Engine temp, Air temperature
RPM, Max RPM
Speed, average speed, max speed
Aculumitated milage (odometer)
Ride milage (trip odometer)
Acumulated Ride time (HR meeter)
Ride Time
Programable Shift Lights, and Engine Temperature Waring lights.
I am thinking about the vapor personally
It is a nice setup. Just make sure you run BR8ES PLugs instead of the B8ES's. The non resistor B8ES plugs will cause interfearance and cause the computer to screw up. I was getting RPM readings with B8ES plugs and didnt even have the RPM sensor lead pluged in to the vapor.
