rla_banshee Posted September 14, 2008 Report Posted September 14, 2008 bought a banshee has fmf fattys, dyna fs comp, new plugs ngk, internals stock! start the banshee up but wont stay on unless i hold the throttle a little its annoying i need help! id rather it idle i know that i can get used to it but id rather not! lol please any help will be useful thanks in advance guys Quote
278 Posted September 14, 2008 Report Posted September 14, 2008 Hey bro I had the same problem with mine when it was stock and the guys on here helped me out. There are these things called TORS (throttle override switch) on top of the carbs. Your suppose to be able to adjust those to get it to idle but I found out that doesnt work from experience. Basically you have to buy the $50-65 TORS eliminator kit which basically just gets rid of those and connects the throttle cable straight to the carb. call Jeff at F.A.S.T. and he can help you out here's a link to his website FAST Quote
rla_banshee Posted September 16, 2008 Author Report Posted September 16, 2008 Hey bro I had the same problem with mine when it was stock and the guys on here helped me out. There are these things called TORS (throttle override switch) on top of the carbs. Your suppose to be able to adjust those to get it to idle but I found out that doesnt work from experience. Basically you have to buy the $50-65 TORS eliminator kit which basically just gets rid of those and connects the throttle cable straight to the carb. call Jeff at F.A.S.T. and he can help you out here's a link to his website FAST nobody???? Quote
rla_banshee Posted September 16, 2008 Author Report Posted September 16, 2008 Hey bro I had the same problem with mine when it was stock and the guys on here helped me out. There are these things called TORS (throttle override switch) on top of the carbs. Your suppose to be able to adjust those to get it to idle but I found out that doesnt work from experience. Basically you have to buy the $50-65 TORS eliminator kit which basically just gets rid of those and connects the throttle cable straight to the carb. call Jeff at F.A.S.T. and he can help you out here's a link to his website FAST cool will have to try does that kit come with new cable??? Quote
travis6767 Posted September 16, 2008 Report Posted September 16, 2008 ya the kit should come with the cable to Quote
rla_banshee Posted September 16, 2008 Author Report Posted September 16, 2008 ya the kit should come with the cable to so itll fix that prob deff??? wheres the compnay located imma need these asap! sounds good my setup is prob custom ill take pics tommorow Quote
travis6767 Posted September 16, 2008 Report Posted September 16, 2008 located in holton,KS www.farmandsandtoys.com Quote
MikeNick Posted September 16, 2008 Report Posted September 16, 2008 so itll fix that prob deff??? wheres the compnay located imma need these asap! sounds good my setup is prob custom ill take pics tommorow FAST is located in Kansas and what do you mean your setup is probably custom?......... Quote
rla_banshee Posted September 17, 2008 Author Report Posted September 17, 2008 FAST is located in Kansas and what do you mean your setup is probably custom?......... doesnt look like a kit ive seen before like a custom welded mannifold could be just me my first banshee excuse me Quote
