This Banshee Is set up for aggressive woods riding
Motor:
woods port by RB racing Michigan 40 over with break in cycle done
True and welded crank with TZ Bearings stock stroke done by Passion Racing all new seals on bottom end
Vito's head with pump gas domes also have 110 domes
Dyno Port 2 into 1 pipe
Trinity 2 into 1 intake with 33mm carb with airbox With Terry cable thumb Throttle real easy on the thumb!
Vito's heavy duty clutch with F.A.S.T springs with ez pull clutch perch
Dyna Ignition with 4 power curves
high flow impeller with in-line cooler
Chassis:
lonestar +2 +1 a-arms with yfz 450 shocks
lonestar -1 swingarm with Honda style rear bearings
lonestar stock to +4 adjustable axle
Full skid plates all around
Beadlocks all around with razor 2's with 80% tread
$3000 Firm
