beef100proof
Everything posted by beef100proof
new price 3200 or trade for banshee of similar value or utility quad
Duncan National Motor with high compression piston stage ii cam full fat boy exhaust Roll Design front end with Axis shocks Axis shock on rear Douglass Shamrocks with GNCC Tires Flexx bars with handguards Full skid plates Oversized gas tank Edelbrock Doug Eichner Carb with twist also have stock set-up Rock pro peg nerfs with heel guards Plastics are good quad is clean This is a turn key race quad asking 4000 or would trade a banshee of similar value for a utility quad 450 or larger location Illinois
SOLD
I'm looking for a crank stock stroke with low hours on it
I'm live in the south suburbs of Chicago
The quad has 373 stroker built by R&B in Michigan. It has aggressive port job, cpi's, nos head with custom cut domes 110 octane required, heavy duty clutch with billet basket and pancake bearing, 35mm pwks with billet intakes. The front end has long travel lager +2 with elkas w rezi's set up for 250#rider the back shock has been re-sprung. The quad has a decent amount of bling very clean and reliable can email pics
I'm looking for a set of elka's for the front and a rear shock. I'm not worried about the rating I'm gonna have them re-valved. I'm also looking for a steering stem +2 for fat bars and a steering stabilizer
how about a set of fatty's with turbine core 2's chrome for 225
This Banshee Is set up for aggressive woods riding Motor: woods port by RB racing Michigan 40 over with break in cycle done True and welded crank with TZ Bearings stock stroke done by Passion Racing all new seals on bottom end Vito's head with pump gas domes also have 110 domes Dyno Port 2 into 1 pipe Trinity 2 into 1 intake with 33mm carb with airbox With Terry cable thumb Throttle real easy on the thumb! Vito's heavy duty clutch with F.A.S.T springs with ez pull clutch perch Dyna Ignition with 4 power curves high flow impeller with in-line cooler Chassis: lonestar +2 +1 a-arms with yfz 450 shocks lonestar -1 swingarm with Honda style rear bearings lonestar stock to +4 adjustable axle Full skid plates all around Beadlocks all around with razor 2's with 80% tread $3000 Firm
I have a Dyno Port 2 into 1 exhaust that looks great. If someone is looking to get low end power this is a good pipe. 150 shipped within the US
I'm selling a set of T-5's with silencers for a 125 shipped with in the US. They are in good shape no dents the pipes have been ceramic coated silver. Can email pics
I have installed a set of lsr 2 plus 1 a-arms on my shee and was trying to use my 450 shocks. I had no installation instructions for the arm and lsr has nothing on their site. I imagine they can only go on one way. I have them on but the shocks have barley any clearance from the upper a-arms. I this because the 450 shocks are so much larger than the stockers and aftermarkets or are a arm not installed right. Like I said they dont look right, the uppers and lowers should be in line with each other right.
I have a trinity stage iv 35mm single carb set-up with pod and air box adapter $275 shipped I also have a dyno port 2 into 1 pipe with fresh packed silencer in perfect shape for $200 shipped I also have a set of t-5 with silencers not chrome but ceramic coated in good shape for $175 shipped I can email pictures
the 450 was worth way more than the banshee I dont know what else you want ill give you the slip on, or do you want the banshee back.I havent rode it since I got home. The sprockets are sidewinder"s guaranteed for life. The brakes worked good you rode the damn thing, That aint right tryin to sell that title,I resent the comment you made about me screwing you over
I have a 99 banshee set up for mx in excellent shape might be something youre interested in my email is bucksplace100proof@comcast.net (keith)
I adjusted the throttle cable at the top of the carb and it idles fine never fowls plugs or overheats
not that bad of a road trip anywhere to ride out there
chicagoland area
I have a 04 yfz 450 with clear title set up for x-country racing I was looking to trade for a nice dune banshee following options are complete lrd pro4 exhaust 06 crank with oil mod high compression piston new dirt digger clutch houser +.5 a-arms lonestar swingarm elkas all the way around with linkage set of 4 beadlocks with razor 2's with 80% tread durablue axle stock length anti vibe stem with fat bars full skid plate and swingarm skidplate large fuel tank sidewinder sprockets case saver wave rotor in rear pro-peg nerfs pro-flow intake longhorn front bumper carbon nose has small crack can e-mail pics file too large
RPM Dominator +2+4 Axle
beef100proof replied to LaegerMXshee88's topic in For Sale - Parts & Accessories
do you still have -
I have a -1 lonestar with with carrier and chain slider perfect shape all bearings are good, 450 shipped new email bucksplace100proof@comcast.net
I looking for a complete motor something with a solid bottom end possibly a 421 cheetah with power valves. Also it you have pipes and 35's to go with it
cheetah cubs for sale!
beef100proof replied to THEREALBUDLIGHTBANSHEE's topic in For Sale - Parts & Accessories
do you still have them if so call me 7083726747 keith
