beef100proof Posted September 11, 2008 Report Posted September 11, 2008 This Banshee Is set up for aggressive woods riding Motor: woods port by RB racing Michigan 40 over with break in cycle done True and welded crank with TZ Bearings stock stroke done by Passion Racing all new seals on bottom end Vito's head with pump gas domes also have 110 domes Dyno Port 2 into 1 pipe Trinity 2 into 1 intake with 33mm carb with airbox With Terry cable thumb Throttle real easy on the thumb! Vito's heavy duty clutch with F.A.S.T springs with ez pull clutch perch Dyna Ignition with 4 power curves high flow impeller with in-line cooler Chassis: lonestar +2 +1 a-arms with yfz 450 shocks lonestar -1 swingarm with Honda style rear bearings lonestar stock to +4 adjustable axle Full skid plates all around Beadlocks all around with razor 2's with 80% tread $3000 Firm Quote
