twinrock Posted September 9, 2008 Report Posted September 9, 2008 im going to buy a noss head but not sure what domes to run..my engine has a mild port and a 4mm stroke crank currently running a stroker spacer plate, im at sea level and run regular unleaded pump fuel 28mm flat slide carbs premix 32-1 i have no experience with domes all help welcom thanks Quote
twinrock Posted September 9, 2008 Author Report Posted September 9, 2008 it also runs a advance timming plate +4deg and i will be buying vforce3 reeds if they are of any consequence thanks im going to buy a noss head but not sure what domes to run..my engine has a mild port and a 4mm stroke crank currently running a stroker spacer plate, im at sea level and run regular unleaded pump fuel 28mm flat slide carbs premix 32-1 i have no experience with domes all help welcom thanks Quote
hercalmighty Posted September 9, 2008 Report Posted September 9, 2008 Do you want to keep the spacer plate or go with stroker domes? I would go with the stroker domes. Give Dave at Noss a call he will help you out with what domes Quote
twinrock Posted September 9, 2008 Author Report Posted September 9, 2008 im in australia so a call might be out of the question..lol..does he have a web site or email thanks Do you want to keep the spacer plate or go with stroker domes? I would go with the stroker domes. Give Dave at Noss a call he will help you out with what domes Quote
hercalmighty Posted September 9, 2008 Report Posted September 9, 2008 Just click on the sponsor banner and he has a email. Also you can PM him on here. He's name on here is DLNOSS I think. Look it up and send him a PM Quote
05.Banshee.SE Posted September 9, 2008 Report Posted September 9, 2008 What's your elevation? Do you want to run race fuel or 93 (or better) pump? Quote
