jamebo Posted September 7, 2008 Report Posted September 7, 2008 Just did a compression test cold and got 153 on left cylinder and 155 on the right. Is it a normal occurance to have a couple pounds difference between the cylinders? (21cc domes) Quote
dragbanshee Posted September 7, 2008 Report Posted September 7, 2008 Just did a compression test cold and got 153 on left cylinder and 155 on the right. Is it a normal occurance to have a couple pounds difference between the cylinders? (21cc domes) I think within a couple is ok. Quote
TeamRealtreeHD Posted September 7, 2008 Report Posted September 7, 2008 Yes, you are fine with a few like lbs. Keep an eye on it, write it down and keep a good log of it whenever you test it. When you see a bigger difference in the sides, rip it down and investigate. Most will say a 5-6 lb. difference. But your situation seems perfectly normal Quote
jamebo Posted September 7, 2008 Author Report Posted September 7, 2008 I'm glad to hear that's normal. Thanks alot, guys. Quote
