Wheel_Works Posted September 3, 2008 Report Posted September 3, 2008 (edited) I have a 1996 Yamaha Banshee. I put everything in a Lightened 89 J-Arm frame(needs Powdercoat). New 12.5" Marvin shaw shocks on the front and a R-1 shock in the rear, +6 swingarm and Stainless braided rear brake line, New chain and sprockets, Plastic is race cut and a stainless grill has been installed, custon seat cover installed, Skat-trak Mohawks on Douglas wheels, New 20X10X8 Skattrak 8 paddle Extremes on Douglas wheels, Aluminum Cascade Handle bars and new Pro design Teather switch, Set up with twist throttle. Wiring harness is as simple as it gets-3 wires. Cdi box is under the radiator in the front. The motor was completely built by Dan Hull @ A&S Racing. The top end is off the motor and motor is out of bike(Fresh Bore and pistons By Dan also). Stage 3 plus port work, Cut head for race fuel, R-1 clutch kit and roller clutch bearings, Shift-star and shift drum mod, Crank is rebuilt, new crank bearings and trued and welded, All new seals, Billet timing plate, lightnened flywheel, V-Force 2 Reeds, Carbs are bored to 27.5mm, Also have a fresh set of A&S Alcohol carbs, New K+N filters. CPI inframe drag pipes/Sparkies. Bike ran 5.13 in 300 ft with stock carbs No trades and $2000.00 Firm Bike is in Mid-Michigan Call or email me HERE I don't get on here much anymore. (989)701-0238 Rich Edited September 3, 2008 by Wheel_Works Quote
OKCterror Posted September 3, 2008 Report Posted September 3, 2008 where are you located and can you put up some more pics please. Quote
Wheel_Works Posted September 5, 2008 Author Report Posted September 5, 2008 I'm in Mid-Michigan. I have to dig the bike out of the back of my garage this weekend and I'll take some more pictures. Quote
SAVAGE420 Posted September 5, 2008 Report Posted September 5, 2008 (edited) I have to dig the bike out of the back of my garage this weekend Take your pic... http://www.chinashovel.com.cn/image/11.jpg :laugh: Edited September 5, 2008 by savage420 Quote
Wheel_Works Posted September 14, 2008 Author Report Posted September 14, 2008 (edited) I put the bike back together yesterday. Started 1st kick. Edited September 14, 2008 by Wheel_Works Quote
MarineNYC Posted September 14, 2008 Report Posted September 14, 2008 Part it. Its worth more than 2000. Quote
Wheel_Works Posted September 14, 2008 Author Report Posted September 14, 2008 Part it. Its worth more than 2000. I here ya. I might just do that. Quote
arfountain Posted September 14, 2008 Report Posted September 14, 2008 Yeah, I thought about buying it from you just to part it. So if you decide to part it let me know, I definetly want those pipes. Quote
STINKYDELUXE Posted September 14, 2008 Report Posted September 14, 2008 do you have more pics of that rear shock? did you have to get it revalved or anything? Quote
