gmctruck1976 Posted August 31, 2008 Report Posted August 31, 2008 Hi having a hard time figuring out what size carb to go with. I am planning on using a 2 in to 1 system on a 421cc stroker engine v force 3 reeds and fmf pipe. Ive already got the 35mm pkw. What im not sure is if this will feed this beast enough fuel im afraid it will run lean with this carb. even jetted. Im sure im going to get a lot of responses that say lose the 2 into 1 set up. I know that 2 carbs will get killer top end if i would use 36mm or 38s. so im not sure weather to bump up the single carb size or not here. another question is were a newer style EDELBROCK carb would preform on a two stroke dose any one know much about them? Quote
