njbansheerider
Everything posted by njbansheerider
  1. other stuff and this stuff is on ebay now auction # 7903289189
  2. banshee is still up for sale , parts but motor must go 1st or trade. if u want to trade tell me what u got and maybe we can work out a deal. plus i have other things i am selling that can go right now. i am parting out this banshee if u see anyhting u want let me know but the motor must go b4 the rest of the quad. this motor was built by A&S banshee (dan hull) he dynoed this motr at 86hp in his shop running on 110 oct race gas. the motor has over $2000 into it. if u have any more ???? post in here or pm me banshee motor that was built by Dan Hull at A&S banshee racing.this motor has a ton of work done to it. the motor is 20 over with a&s banshee modded wiseco pistons to match the port sizes and have been lightened. it has a duncan racing power head with 19cc domes cut down to 14cc domes. the motor has been ported and polished for drag. it is a level 6 port job welding & reshaping of transfers.Cut & Rechamber head. port matched cases. hinson clutch basket and barntte clutch. it has a hot rods trued and welded crank. it has shift star mod. v force reeds. pro design water pump impeller and pro desigh ez drain plate. it has a case saver to keep the chain from breaking the case. white brothers boost bottle and stock intakes. ricky stator high output stator and timming plate that gots from -10 to +10. the trans has been serviced and all seals have been change and the motor is still running great. this motor was made to run on race gas, alky or meth. only. this bike was dynoed at 86 hp running on 110 octane fuel. i ran motul 2 cycle oil at 32:1and motul trans oil. the is prob somethings i am forgetting. the pipes i have are brand new toomey tr6's with 0 rides on them. i was use 28mm pwk carbs.
  3. i also got 3 +4 swing arms and 1 rpm bearing carrier i can sell right now. i will get pics of that soon
  4. i am selling a 2000 banshee motor that was built by Dan Hull at A&S banshee racing.this motor has a ton of work done to it. the motor is 20 over with a&s banshee modded wiseco pistons to match the port sizes and have been lightened. it has a duncan racing power head with 19cc domes cut down to 14cc domes. the motor has been ported and polished for drag. it is a level 6 port job welding & reshaping of transfers.Cut & Rechamber head. port matched cases. hinson clutch basket and barntte clutch. it has a hot rods trued and welded crank. it has shift star mod. v force reeds. pro design water pump impeller and pro desigh ez drain plate. it has a case saver to keep the chain from breaking the case. white brothers boost bottle and stock intakes. ricky stator high output stator and timming plate that gots from -10 to +10. the trans has been serviced and all seals have been change and the motor is still running great. this motor was made to run on race gas, alky or meth. only. this bike was dynoed at 86 hp running on 110 octane fuel. i ran motul 2 cycle oil at 32:1and motul trans oil. the is prob somethings i am forgetting. the pipes i have are brand new toomey tr6's with 0 rides on them. i was use 28mm pwk carbs. the stem is a roll design but like i said i need to sell the motor 1st.
  5. i am parting out this banshee if u see anyhting u want let me know but the motor must go b4 the rest of the quad. this motor was built by A&S banshee (dan hull) he dynoed this motr at 86hp in his shop running on 110 oct race gas. the motor has over $2000 into it. if u have any more ???? post in here or pm me
  6. i took the yfz450 shocks off my 450 to put on my banshee and the 450 shocks are about 1" too long and i got +2+1 a arms
  7. i will be at budds creek, mt morris and southwick. maybe ringGold
  8. look closer some of the races are dirtbike only
  9. i will be at 3or 4 nationals
  10. Are you tlaking about the key switch on the switch on the handle bars ? If its the key swittch all you have to do it put the red and black wire together and if your talk about the handles bars switch just unplug it
  11. How much do you want for the airbox + shipping to 19007 ?
