I have a 2003 banshee that I just went through. New 64.25 pro x pistons fresh bore, midrange porting, fmf Fatty's, 19cc? (I think} cool head 130 psi compression, stock carbs pod filters with what I thought was optimized jetting for the combo. I think I am.at 330 main 35 pilot but I'd have to check.
The thing was running great other than a hard first start of the day. Drive 600 miles to silver lake sand dunes ORV, and I won't even pull itself up the sand road to the dunes. Elevation is only 300 ft more than home, so I don't think that's enough for a major jet change.
The right side plug is clean, left side plug gets wet. By feeling the exhaust output when I rev it, I can definitely tell the left side is not running as good as the right side. And the left side pipe doesn't get as hot. But it sounds like it's running on two cylinders and idles fine, just makes no power.
Both cylinders have the same compression, right has 2% leak down, left has 3%. I don't think that's too far off. Reeds look good, Carb jets and passages all seem to be clear and open. I swapped plug wires side to side and there was no change. I am considering swapping carbs to see if the problem follows the carb, but otherwise I am out of ideas. Does anyone have any ideas?
